123hotchef
- Kent
its the lamp giving that voltage drop take the lamp out and the voltage at the tank is 11.98
hey good shout i did put 1kg the whole bag into the cwst about 25 galons
A standard car battery charger (transformer and rectifier) isn't a constant current source.
Yes, what you are talking about is a situation where the load i.e. an LED has a complex resistance which varies with voltage. Typically this very (very) low resistance would allow way too much current to flow so you use a resistor in series, typically 100 times higher than the nominal "resistance" of an LED. Almost all of the voltage drop is across the resistor.
In this case the load is a bucket of electrolyte with an unknown resistance but probably circa 20ohms (i.e 1A @ 12V). But most importantly, you are not connecting a simple DC source like a battery, most people are using a constant current source like a battery charger. Without some deeper knowledge of how the output of that charging circuit has been designed, you really can't tell what difference an additional load (like a simple bulb) is going to make,
On the other hand, a PC power supply is more likely to be designed to operate as a constant voltage source. Again, you have no idea what an additional load will do under those circumstances.
So in practical terms, unless you are using a simple battery to drive this circuit, a bulb in series with the electrolysis bucket is literally a waste of energy and it is MUCh easier to moderate the total current flow by varying the resistance of the load by varying the concentration of electrolyte.
If the volts are dropping, the circuit is drawing too much current.
Your setup looks really good but are you sure the plastic tank isn't also conductive? If it's a glassfibre tank it might well conduct when it gets wet and some plastics also can conduct.
A bulb in series will do nothing to limit current, that's an old wives tale. All it will do is light up and tell you if the power is on! A bulb is not an active component, all it does is dissipate energy. If you connect 12v across a 12v bulb rated at say 20w then it will dissipate 20w of energy. Bump the volts up to 24v and the same bulb will dissipate 40w except the rating generally tells you how much power a bulb can dissipate before it blows up!
Secondly, people use a bulb to "limit" current, when all they are actually doing is moving the useful energy from your tank into the bulb. The same total current will flow. So if you want to limit the total current you need to increase the resistance of your tank or lower the voltage. Much easier to increase the resistance of the tank by just not putting so much electrolyte in it. For a bucket that size, I'd start with a cup, maybe two cups of washing powder (i.e. one containing sodium carbonate).
Anything more than an amp at 12v is a waste of energy. You want to cajole those iron oxides from the cathode there's no need to rip them off unless you're in a hurry. It looks great when everything is bubbling and fizzing away but the more gentle process gives the better result. Higher currents do not allow the reduced iron molecules to bond as strongly with the surface being de-rusted. Net result is much more deterioration of the workpiece and higher currents will destroy any fine detail that may have survived under all that rust.
So: check the tank is non conductive and use less electrolyte. You can safely start the process without any and just add it until you get just over an amp flowing.
Stick a bulb in series if you want top light up the garden. it will do nothing else for you...
it is worrying that the led on the power supply goes dim and the voltage goes down when I connect it though
