Screwdriver
From that post I can see that you either misunderstand the terms 'regulated' and 'constant', or that you have difficulty with explaining it -- neither of which is an insult btw, but if you're trying to give advice it'd be nice if it were correct...
Well I must admit, I am struggling not to feel insulted but hey, if you don't really mean it, that's fine; it's you who are struggling to explain yourself.
If I was writing a thesis on the subject I would be more careful with my description and not use common vernacular which also has a related technical meaning. Like current dumping for example.
I'm not going to bang heads with you. The detailed technical explanation is irrelevant in this context though it is tempting to watch you try and explain the difference between "current limited" and "constant current" within the context of your disagreeing with my comments regarding typical battery chargers vs. PC power supply.
I introduce the conceptual difference between these two types of power sources merely to remind the casual viewer there is no such thing as a typical DC supply. Just because it says 12v on the box doesn't mean it's going to give you 12v to your tank. Nor can you just stick a bulb in series with <insert random device here> and everything will be fine.
Using a bulb is a waste of energy unless you want to see what you're doing. The best way to limit the current flow in an electrolysis tank without having to delve into the precise technology of your power supply is to vary the concentration of the electrolyte.
