I cut this for someone from 3mm steel, powder coated it should last a good few years.
What about the Whippet Inn, the Whippet Out and the Wipe it off?Could you do one for the local dogging spot called the Whippet Out?
Laser water jet cut plastics fused to a thick white plastic middle core , good for 40 years unless we have a nuclear war.
Look on line for acrylic plastic sign makers who use water cutting jets to cut the shapes .Sounds expensive! Ideally she wants a regular who runs a firm that does that sort of thing.
What plastic and how would you fuse one to the other?
You've given me an idea though, stained glass could look amazing...
I'd use a rubber mallet, go easy on it. You don't want to start bashing it with anything harder or you'll risk spreading the metal and compounding the problem.How can I flatten this ali sheet? There's some ripples in it. Lay on the flat board and gently tap with a rubber mallet or get a lump of hardwood and hammer that against the sheet? Cheers.
That should be outside a knocking shopI cut this for someone from 3mm steel, powder coated it should last a good few years.
Kin Charlz du Turd.... Corination street .. a chariti bash, Pin a tail to the cow & win £10 ?Pub related, as I've just come back from it...
Looking to do a Coronation celebration up the pub to mark King Charles III ascension to the throne. Live band, food etc.
Sat 6 May is the actual coronation. Everyone will be at home watching on the telly.
Sun 7 there'll be numerous street parties.
Mon 8, I believe the King has suggested it be a day for charity work etc. Plus folk have to go to work on Monday.
The plan then is maybe Sat 13th as a late celebration. We were all trying to think of a catchy name for it to go on the posters.
Charlie's Bash, Coronation Celebration etc.
Any ideas welcome!
