premmington
- Norfolk
As would grinding a thin slot & using a screwdriver lol
That made me laugh! Teehee!
great news its out...ok ive took a day off work tomorrow and ime coming down the M6 to your place with my bench grinder,ile put a new point on your centre punch for yaGood job I had that 5mm to play with. Inside the hole would've ruled this out.
At least I've made a start re my long time wish to do some welding....even if only to make contact.
I have got some projects in mind but have more pressing stuff to get out of the way first.
When the decks are clear it will be my pleasure to return.
I've really enjoyed this despite my problem being a real PITA and boy what a responsive forum.
In the meantime I'll keep my eye open for a more powerful rig at the right price.
Once again...thank you all for your help/encouragement.
your best bet would be to use a soldering iron then a girly nail board to shape the solder into a pointgreat news its out...ok ive took a day off work tomorrow and ime coming down the M6 to your place with my bench grinder,ile put a new point on your centre punch for ya. Whats the best way to put a point on a punch chaps,use heat or do it cold???
Nononono, all wrong; you must use welsh steam coal to heat to a white heat, then work a new point on the end with a 12oz ballpein. But you must use air from a set of bellows for draft as electric fans are too harsh and the work must be done on at least a 8cwt London pattern anvil, none of the weirdo double bick nonsense.your best bet would be to use a soldering iron then a girly nail board to shape the solder into a point
The now-removed nightmare bolt's in the photo (It's 70mm) along with the very unremarkable equipment used to persuade it
i.e. I've just removed it by centre punching the thing round for about an hour.
I think constantly oiling the bolt hole over several days
did the clocks going back cause coefficient of expansion ultimately resulting in the breaking of the bond
HE HE Yeah I think there many of us on here that would like to do both of those.I'll come back when I've cleared the decks as I would like to do some proper welding.
>If you dont have whats needed to do the job, better to get help
That sounds sensible and I note Richard is 12-15 miles away.
Richard...what would you charge for a trip out to West Heath if indeed you're not indisposed to the same.
If you are no problem and thanks for your input.
He got it outI know some time has passed, if it is not sorted I can come and give a hand, just drop me a message as I work a lot and do not always come on here
Did nobody mention stud recovery arc electrodes? I've used them and they beat just about anything I've seen hands down for removing siezed bolts.
They sound really good JD. Can you recommend a supplier?
