premmington
- Norfolk
Nice tight fitting washer over protruding snapped bolt! Weld washer to bolt. Then weld M10 17mm hex nut to washer inside and around the circumference of washer. MMA 110amps DC+ 312 rod. Loads of heat, while it cooling spray with WD40.
% chance very good. If you fail, grind the weld off and start drilling.
I have succeeded more times than I have failed!
This is what MMA welding was designed for! Loads of heat and penetration with slag surrounding it!
I am a car mechanic, I have removed loads of snapped bolts in thirty years with this method.
