chrisg3103
nicely trolled, did you try all your combinations when the external input light was lit up on the panel?
Yes I am sure I did, can't recall if I tried to weld and adjust but definitely tried the others.
Have you put it in remote mode?My foot pedal on the Sherman seems to just be an on off switch, I thought it was supposed to be like an accelerator? What am I doing wrong?
Genius! Thanks!Have you put it in remote mode?
Press the pedal down and hold until you hear 4 or 5 beeps and then you will see the remote logo light up on the lower right side of the panel.
Let us know if it works. I never use a pedal so don't have one but one day I may decide to put the pot insert on the torch, probably won't though as I think it only works in 2T on the Sherman/Jasic.Genius! Thanks!
It did work! I must admit I didn’t know there was such a thing! Had to look at the jasic manual to find out how to do it!Let us know if it works. I never use a pedal so don't have one but one day I may decide to put the pot insert on the torch, probably won't though as I think it only works in 2T on the Sherman/Jasic.
You are late to the show and the troll is back under the bridgeOh no mate why ??
That is where I saw it, also the Razorweld one, never looked at the Sherman manual as I can't read PolishIt did work! I must admit I didn’t know there was such a thing! Had to look at the jasic manual to find out how to do it!
BTW anyone wanting to put a quick release on the front for the torch could do so relatively easily as there is loads of room, it is not something I will bother with.
Yes, the one in the Sherman is 10mm threaded but the latest Jasic have the rectus style connector.Are you talking about replacing the threaded gas connector with a bulkhead fitting Rectus 21 type?
Colin
Just buy another Sherman and rob the connector off the back and fit to the original ShermanThe jasic has quick release front and back.
Which makes life so nice to be fair. And if I can find the connectors cheap enough will be converted on most welders I get.
Just buy another Sherman and rob the connector off the back and fit to the original Sherman![]()
I'm not that badHe would really need the bulkhead type if replacing the threaded fitting.
Kind offer, appreciated.No worries could have posted you some if they had of fitted . Not to worry
