Moose McAlpine
- Norf Lund'n
If I remember correctly (?), it was an engine driven deck washdown pump, of which I have zero experience, we have a bloke who washes our boats, he's great.
I'll get back to you tomorrow.PM sent.
The joys of rear wheel drive.Put a new clutch in the Sprinter yesterday.
Had an odd issue with the clutch getting heavy when not used, like in one gear on the motorway for a long time.
Aside from being annoying i didn't want it putting extra strain on the hydraulics and causing the slave cylinder to fail.
Such an easy vehicle to work on.
I just drilled a hole in the cistern top, fixed a length of fence wire to the plunger top and made a flat hoop for a handle, cos I'm not a savage.I fixed the toilet flush handle that snapped yesterday. A new cheap one from Toolstation, five minutes and job done. So satisfying to fix something first attempt after weeks messing around with the Fiat 500
No pictures as it's just a bog flush handle!
Blimey, just like they used to do it.So little needs to be removed to get the gearbox out, and it's all done from the back.
Ive recently got a little steam engine that I'm refurbishing. It works fine, but the crankshaft runs though the firebox and the holes for it aren't in alignment. After 60 years running its not a big problem, but it annoys me.
so I though I'd weld the hole up so I can redrill it later
the casing is only 0.5mm thick, so I clamped it to some 1/4" thick copper and fired up the mig welder as I'd been doing some welding on my car earlier.
and after bit of cleaning up its good to go, and still flat.
too many ugg a dugga's BobMore truck mending, fitted a new set of air bags. Don’t last long in this game, give me springs any day.
View attachment 420420View attachment 420419
And fixed a Transit brake judder, disc looked ok but had about 6mm run out. Turned out to be three sheered of bolts and of the two remaining one was in cracked out thread.
View attachment 420426View attachment 420427
