- Birmingham
Not today but Monday and not exactly fixed, but... had a breakdown callout from a customer 180 miles away. Radiation warning light not working.
Drove down, was told they'd tried a new LED cluster to no avail. So I swapped the cluster from one lamp unit to another and it worked, which meant there was no supply geting to the lamp unit.
Now, a requirement of the Ionising Radiation Regs is that no x-rays may be generated if all lamps arent lit, hence they couldn't do any work, so the system was doing what it should. But how do you know if the monitoring circuit for the lamps is working? In this case we fit a pushbutton so that when you put the system into Test mode, you can manually switch all the lamps on or off to check if the monitoring drops the interlocks out.
Someone had left the button in the OFF position...
That'll be £1000 please.
We had a new machine at Rover that had a 2 metre long control panel covered in various coloured lamps to show the status of the machine, the publicity dept, wanted a photo will all the lamps on so if you looked carefully at the photo you can just see the tip of a finger at the bottom left of the panel holding the lamp test button down
nowadays you'd Photoshop the hand out. Actually, thinking about it I have written user manuals that had step-by-step instructions with pictures, and I copied and pasted lit lamps over unlit ones to make the representations look right.
