ooooh . . . that's stuffed it . . . somebody will dump a fully legal camper van and disappear . . .thats where i park and have never had anyone park there. in 8 years...
You could fill it with dirt...perfect. i could use a new camper
Haven’t seen one of those in years!View attachment 468797
Well the day was busy, so why not do more.
When I got it, it didn't work.
Oh look a new bulb was fitted and................
Ok, The old one was very tight to remove, but a bit of applied force and it was free.
BBQ rattle can paint, as it had rust killing elements.
Fixing the earth point.
Just passed the PAT.
Plain bushes are much better suited for use in a swinging arm.If that's the swing arm bearing, then perhaps it never moves enough to do much rolling of the needles? Looks more like fretting then actual rust. If the needles don't roll, the grease doesn't move to actually do what it's supposed to and the bearing false brinells. There are some grease scout there that claim to help - been looking at similar issue on a $3m machine.
For automotive I would use CV joint grease as it is for oscilating parts.If that's the swing arm bearing, then perhaps it never moves enough to do much rolling of the needles? Looks more like fretting then actual rust. If the needles don't roll, the grease doesn't move to actually do what it's supposed to and the bearing false brinells. There are some grease scout there that claim to help - been looking at similar issue on a $3m machine.
well that was a lot of sweat...just started grading it out. no more material should need to be removed, just moved about.
its pretty nearly there now, just have to get the grade right, compact it with the wacker plate, pour the retaining wall, put ground fabric down, sharp sand then block paving. once done ill pour a concrete wedge along the front and job jobbed.
Not surprised I'm knackered just looking at it!well that was a lot of sweat...
final grade and compacted
road fabric and shuttering completed (i know its not straight. i ran out of motivation. never let perfect be the enemy of good enough. its not as bad as it looks in that pic) it gets wider as it gets closer to the road as the depth increases. this is intentional.
and poured. 3/4 ton of aggregate(a guess, may be less...), and 2.5 bags of cement.
i am absolutely knackered.
its starting to move again and im getting concerned about fatigue. considering the use its had, its done well and im not upset about having to beef it up.i might have slightly overloaded my trailer with wall debris when taking it to the tip. by about 150%....
it'll be reet! turned into bugger when i went over a particularly aggressive speed bump and bent a axle so the tyre was cambered enough to be hitting the bodywork even when empty.
now the correct fix is to put a 1 ton plus solid axle underneath. the fix available to me is a porta-power and a sledge hammer.
its straight again... for now.
some research has been done. rx8 wheels are damn near the same fitment, just the center bore is 3mm smaller. so im going to drop 2 of the many rx8 wheels i have off at the machinists on monday to have the center bore turned out and therefore i dont have to bother with finding wheels. modifying the hubs was also a option but it would mean i cant just use the astras spare if i get a puncture...its starting to move again and im getting concerned about fatigue. considering the use its had, its done well and im not upset about having to beef it up.
now i was going to find something like a original transit connect rear axle and butcher that, but ive had a thought.
lookit what i have.
2x astra j estate rear hubs. one used, abs magnet fell off, and one new. so ill fit the other new one to the car, then make a couple of backplates up to fit the hub out of (15mm?) steel plate (ideas here on how heavy it needs to be to reliably carry a ton plus off-road only ofc ) then weld it to some heavy box. (50mm i think) and obviously gusset it to make it nice and strong. then just weld it, no suspension, to the bottom of the trailer and job done.
