Hi @selectedgrubHi @Dr.Al I like your machine.
Do you hand work the piece your filing into it?
Or if your filing a key hole for example would you thread the file through a precut hole?
Thanks for sharing, Have a Happy new year.
Hi @selectedgrub
Thanks. I'm not sure what you mean by "do you hand work the piece your filing into it",
Yes.Thanks for the explanation.
To file the slot you posted did you just push the working piece in to it?
Extra clamping rigidity and mass for vibration dampeningCan I be dumb and ask the use of a boring bar sleeve? I will assume it’s a sleeve that slips over the bar with the correct OD for the hole so stope rattle/ flex of the bar??
What's going in the sectioned off area?
Raised bed for flowers, herbs, anything we fancy really. The wall behind will go higher.What's going in the sectioned off area?
Children or pitbulls, I thought.What's going in the sectioned off area?
Doing some math I get that the heat recovery is 60-65% efficient, which is less than I had hoped. The ideal range is in the 80% range.
