What happens is I start, come across something that takes my attention and I go and attend to that, eventually I get back to the tidying, well for a short time before the cycle repeats![]()
Well when it comes to things I am not really wanting to do then I certainly do have a grasshopper mind, just about to start the tidying up again when I spied the depth stop. It has always been a socket capscrew since I got it and is a pain as I have to go and get an allen key. Well I decided to make up a stainless crossbar one. Hauled a setscrew out the drawer, found some 8mm dia bar and welded them together. Went to try it and the bleeding hole was tapped UNC. I mean UNC on a Swedish drill WTFAh, the old 'grasshopper mind'.....doesn't mean you're a bad person.
the bleeding hole was tapped UNC. I mean UNC on a Swedish drill WTF![]()
Are you sure it isn't Whitworth, aren't the tpi the same on a lot of the sizes, just the angles are different.I could see maybe Whitworth on the Arboga if it is very old but UNC?
I will have to look at the other fasteners and see what they are, I just presumed it would be all metric.
The slate is like 12mm thick, I’ve just roughened up the top edge , the bottom side is a straight cut
@Dennis Aspö
Very good ^^
But I don't like the way the bare tangs of those files are pointing upwards - waiting to impale a hand or wrist, if a person were to fall/stagger/pass out etc....[however unlikely it may seem
Ten glorious minutes ragging a Caterham around nordschliffe and the psu died. Hopefully. Sellers refunding for a new psu and hopefully its fixed.
