Blimey is SWMBO cooking that badChild proof toaster/kettle..
socket turns off the outlets between 2359-0700 and stops you turning them on unless you disable the child lock.
On account of someone attempting to make them-self toast unsupervised
I cleared my shed work benches then filled them again..... seems I have run out of room
If you can see any surface they are not fullI cleared my shed work benches then filled them again..... seems I have run out of room
If it is not he is going to love youIs the dropped L intentional, Brad?
Yes, bloody Americans.Is the dropped L intentional, Brad?
a floor
Now I'm no expert, in fact I'm very much in the learning stage for Tig. I can't even tell if that's stainless or aluminium.Beer/Wine ice bucket for my mrs Company.
Some sort of issue causing soot. Hard to say whether it was the scotchbrite (although I cleaned with acetone) or a gas issue. Either way I need to check connections and lines. I've got a feeling I may have a hole somewhere in the torch cable.
Probably would of looked better if I glued the letters on but didn't have anything suitable.
View attachment 352019 View attachment 352020
Yes that probably would of been a good way of doing it. This is just a freebie job so I didn't want to sink too much time into it.Now I'm no expert, in fact I'm very much in the learning stage for Tig. I can't even tell if that's stainless or aluminium.
Brad, is there any reason you could not have drawn around the letters and drilled 3 small holes from the front, inside the lines of each letter, then plug welded from the back?
Pan head would be better but if thats all youve got use them!
