For a particular use? Or just general pumping of dirty water?
I'm on a project that requires drilling underwater. The holes keep filling up with river sediment between shifts.
One of these is usefulToday, I made some lines on the pillar drill table
I did these deliberately before anyone says anything, and the camera angle makes them look off-centre, which they're not . Due to my compromised sight, I have difficulty when drilling round stock in getting the hole(s) at exactly 90o on the vertical plane, between these and my V blocks it ought to be easier.
I tried a centre-finder but, of course, I needed to move the table in order to remove it and insert the drill-bit . Now I just need to try them, and decide if they're clear enough to see without filling the marks with paint.
Self centering vice
https://www.amazon.co.uk/Self-Centering-Width-Ground-Steel/dp/B076HQ9RMK
Set up once and forget.
you should see the contortions I have to go through when tapping
Not that I am any expert but autogenous will need a bit of spare material to not leave a concavity won't it? Or will that hide in the powder coat?I have been waiting on some Aluminium arriving so decided to get on with the side section for the gate. Managed to get the main frame welded up.
Not sure the best way to weld up the top section, I plasma cut some 3mm sheet to weld into a box but I am kind of dreading it as I know how much stainless moves when welding. I am not used to this type of thing so I was thinking Autogenous might be the way to go, anyone have any thoughts? Maybe @Paul. would be able to suggest the best way?
Pic below of the bit I mean.
I don't really think it will show much as it is a tight fit and I can tend towards rounding the corner with the weld but as said I am not used to working with thin(ish) stainless in this manner.Not that I am any expert but autogenous will need a bit of spare material to not leave a concavity won't it? Or will that hide in the powder coat?
BTW that looks like the worst of my nightmares given my predilection to distortion
Really liking that contrast.The Ali I welded up a couple of pages back has returned from the powder coaters
