DAPPH
as dyslexik as I'm daft
No, he was a decent chap.
I just moved on.
voluntarily or by way of an enforcement ?
I just moved on.
Look at a Colchester with a hard stare and it will twistI was just curious as a test bar will show bed dip where as a short test you can force the bed in to a twist
It is the shipping container where my CNC plasma isWhats in the plasma container? Are you the 5th element
It is the shipping container where my CNC plasma is![]()
Not really, it is brilliant![]()
That was the route I was originally going to take but then decided to go for a folding table and then got gifted the shipping container so built it solid. I still did it to more or les the same plan as the folding one was going to be simply because I was in a rush to get it done and didn't have time to redesign things.I would like to build one like the esab crossbow
Oh and BTW you couldn't get much nearer to water than my workshop, here is a google satellite image, workshop arrowed.
. As a result it should go together better, more accurate and be just more betterer
. We will see, it will be twice the current size and will have a rotary axis (already playing with the software and it works). The original machine will be doing the components for the new upgrade. I will post pic as I go in the plasma section. Wish me luck otherwise I might just pour some petrol on it
Job number one … think they might be called magneto spanners due to them having the two feeler blades for setting the magneto points , but if thy are screw driver blades instead then they are not magneto spanners .
LOL
I used to do all my stuff with a quick sketch then modify as I go but now I tend to model things up, easier to adapt in a model and you can see things that will not work easier and can adapt quickly.
One of the main things I would do is have the slats with points on rather than just flat as it would hold the material off the slats and the dross wouldn't need scraped off so much.
It would deped on the spacing I think.If you mean the dross on the slats? Then I use a penumatic chisel and just rattle the side of a slat and the dross shakes off. A needle scaller would also do the job. Not perfect but good enough. I find that the 'point' slats would make it easier for the smaller bits to partially or fully fall through (get cocked up)
Now, if I could just get the ordinary thing to start...It's only passed...
about 400Are you feeding the five thousand?![]()
