Yes, and I could read between the lines.Humour, my good man, humour...
As you say getting the writing in the correct orientation after it's all folded is sometimes a challenge.
Couple of these barrels rolled up and welded today, fancy laser welded jacket on the outside of the sheet too.
Virtually 8 metre long sheets, so just one seam.
Yeah, just 2 bits of loose fitting tube.Are those rollers on the thingy holding it in the air?
Tip from a company that folded some 3 mtr self reinforced plastisol shelving for me from my technical drawings . " We draw the finished item end on , then prioritise the bends , give the right sequence of priority numbers on the folding schedule sheet , then fold a scrap strip & see if it turns out like you want . 96 shelves later no waste after doing the setting up & schedule .As you say getting the writing in the correct orientation after it's all folded is sometimes a challenge.
Will you be using the engraver to put designs on leather work such as belts ?During a break from work this afternoon, I had a play with new software for the laser engraver. Just a bit decoration for the womancave.
How many thousand of the labels do you still have? " Bespoke part " made in " England " on three lines to me would to me convey a better image of a proper engineer making specials for me ........ might allow a higher price too .Nothing exciting for most but with @Pete. help. I can now create both Metric and Imperial threads the thread dial gear worked perfectly and once I had ironed out the flex drive issue it all worked. Pete also put me on to a 45T gear so I nearly have the full set (only missing the 25T now). I am a happy chap!
You Can get the printer bit that’s usb and connects to your computer so you can type it out if that’s quicker. That type can use much wider tape too.I have the same label maker used mostly for labelling up trestle legs for dispatch... they have long part names and cba writing it all out a hundred times
The only bad thing about them IMO is the ABCDE keyboard, not QWERTY... annoys me every time I have to type out a label.
I bought 500 of them and still have most left. I originally planned on selling the wooden pens I made but ended up just giving them away.... I made 30 for stock and only have 2 leftHow many thousand of the labels do you still have? " Bespoke part " made in " England " on three lines to me would to me convey a better image of a proper engineer making specials for me ........ might allow a higher price too .
Are we going into welding apron fabrication, looks like it should be framed.During a break from work this afternoon, I had a play with new software for the laser engraver. Just a bit decoration for the womancave.
All I wanted to do was move some stuff
Would that be the words or a picture of your something ?Looks fantastic.
Tell me when you commercialise it, I'll have one please, could you put Barking Mats Welding 'something??' On it if I sent you a compatible file, love that, how big is it?
Main parts of the pantograph mechanism for the pantorouter assembled just to see how it all fits together.
