I done that before and put them up for £70. No one was interested at that price which meant earning about £10 an hour I thought why bother.Looks really good, I've made a few but never polished them up like that, looks much more striking. Next time I'm home I might try to knock a batch out and see what I can get for them on Etsy.
That's why I've never done it before but I reckon making ten at a time I could do them a bit quicker. Would probably save a bit of time starting with annealed sheet rather than 22mm water pipe too.I done that before and put them up for £70. No one was interested at that price which meant earning about £10 an hour I thought why bother.
Would you mind if I showed my wife this photo? It might work ...... Or not.
Got a "How to" on these, they are really cool. I have done wooden flowers on my lathe but would like to try theseThat's why I've never done it before but I reckon making ten at a time I could do them a bit quicker. Would probably save a bit of time starting with annealed sheet rather than 22mm water pipe too.
View attachment 274602View attachment 274601
Just had a thought, there's probably money doing metal versions of trendy houseplants, people sell cuttings, literally single leaves, for upwards of fifty quid because they're slightly more variegated than the plant usually is!
The clamp has started working lose when in use so the router blade drops down when taking a cut, machinist jack is my temporary work around
I've got one of those little cheapo lifting tables from the bay that I use to support my router. Not only stops it slipping but makes adjustment a doddle.The clamp has started working lose when in use so the router blade drops down when taking a cut, machinist jack is my temporary work around
Cheers for that! I need that in my life I have a job now and again removing a pump from the bottom of a machine for inspection / maintenance. Its a right pig getting it down on your own and there's no real room. At over £7k I really dont want to drop it..... Thank youI've got one of those little cheapo lifting tables from the bay that I use to support my router. Not only stops it slipping but makes adjustment a doddle.
Mini Lifting Table
I don't want to try your shortbread.Burnt & ******** is the only way.
Droopy.Oh, looks different that way round
