I like that John.I have used router bits on alloy before for light cuts.
Wima MP3Looks like RIFAs, wanna replace those before they blow, they get cracks first, then you know they are goners soon.
Last maybe 20 years in good conditions, moisture sensitive.
Shouldn't thjere be a tap on the drip tray labelled 'Mild'?I finished off the wiring to the downlighter above the new beer engine I fitted yesterday, added a beer menu on the cellar/brewery door, fixed the PC next to the cinema screen, upgraded the software on the pellet boiler, took the dog for a good walk over the moors, now about to settle down and have a beer in the cinema and watch a good movie.
Cheers
Andy
BTW 6Music!
I was looking for a 'Knowing Nod' emoji but couldn't find one![]()
Made a vertical stand for my Aldi portable bandsaw.
A rod through the hollow handle holds it on, two cap screws on the motor housing rest on the back bar and the screw clamps hold it all steady. At present it's clamped in the vice but I might fit some feet on it later. Just need to fit a no-volt switch before I use it.
You want more mass really.Yesterday, I produced this..... a 'prototype' fly cutter, just got the HSS cutter to form into a proper rake/angle. It may or may not do the job, but it cost nothing and was worth a go
Then a torch rest for the MIG which will need clamping to the bench, but again, an old box spanner and a bit of scrap plate, what's to lose..... No pic of this as I'm sure you all know what a combo of those would look like.
A good type to copy is the SubUrban Tool flycutter.Thanks, Brad. It's just an experiment really. I have a lump of round bar of indeterminate quality and might try to copy the more common type you get from Banggood etc. They don't really cost a lot so might just end up sending money East....![]()
Looks like a shell mill getting close up and personal with a boring bar.A good type to copy is the SubUrban Tool flycutter.
It’s just about mass, you can use as small a boring bar or carbide insert as you like.Looks like a shell mill getting close up and personal with a boring bar.I suspect they will need a substantial machine to get the best out of them.
I will try to post some more tomorrowGot some more pics? Mine's still sat in the box tbh.
