Talking of smells. I dug out the cultivator from the shed for the first time in 35/40 years , cleaned the carb and filter bowl , new fuel and it fired up 2nd pull and ran perfectly but filled the garden with smoke for about a minute . The best bit was that I used to put a drop of Castrol R in the petrol and some of it was still in the system . The smell was FABULOUS .
Lovely spalting in the timber , there is a woman somewhere in the UK who is an expert in setting cut lumber so as it get the best spalting occurring in it , as a result her guided timbers are rather expensive . Think there is you tube video with her showing some of the better specimens too.A workmate has a proper bar in his garden. Bar, slot machines, pool table, dart board etc. His missus bought him a brass & ceramic pump handle to mount on the bar. He wanted a "bit of hardwood" as a plinth. Off I went to my friendly DIY saw mill neighbour and got a chunk of beech with nice grain:
These are rough just to see if he likes the idea.
I've started clamping my clamps to the rafters above my lathe so the long legs are over the lathe high up out the way , so far I've not dropped one on the lathe as it's always a two handed exercise putting them up or taking them down.I often find that, when I'm working at the woodworking bench, I need somewhere to put stuff down temporarily. Some of the time I can put things down on one end of the bench while I'm working at the other end, but my bench isn't very long and if the thing I'm working on is large, I quickly run out of space.
In an attempt to overcome that issue, today I made a shelf.
Made out of (and dimensioned based on) what I had: some 750 mm lengths of 3030 extrusion, some angle iron, some chopping board and the last bit of plywood I had.
The plywood is not permanently attached to the rails - it slides on:
The slidey rails were made out an old chopping board (which I'd cut up a year or so ago but still had some bits left). I shaped them with the router:
When not in use (and this is quite important), the table slides off easily and can be propped against the wall. The supports pivot up and are held in place with some magnets:
Crude, but effective.
The reason I can't raise the whole shelf with the plywood attached is that my clamps would get in the way:
The reason it has to lift up is that otherwise I wouldn't be able to get the motorbike in and out:
What it will look like most of the time:
The idea is that stuff that is actively in use goes on there (nothing permanent) and hence the shelf is mostly empty (so I can get the bike out quickly!). I guess worst case, I can always slide the shelf off with the contents still on and put the shelf + contents on the main bench when I want to take the motorbike out.
I'm not sure Treacle approves:
If you ever in any doubt about how little space I've got left in my workshop, I hope this shows how desperate I am for every little bit of space!
Pigeon post ?
Is that a modern safe version of cotton covered three wire rubber sleeved cable Ardy ?Just finished fitting this to a friends wall.
The sparky who re routed the cable left the cable in the right place. Just above a wall nogging. So I had a chance to get a decent fixing in.
View attachment 286503 View attachment 286504
Modern PVC cloth covered 3 core cable.Is that a modern safe version of cotton covered three wire rubber sleeved cable Ardy ?
Just found this UK video about home spalting " woodworking # 77 how to spalt wood 2, part 1 of 3 - YouTube "
It's Creosote! But just neat.Is that modern "Creocote" or the proper stuff mixed 50:50 with old engine oil to make it go further?
Don't let us stop you, but have one back!By God there's some talent on here! I could spend all day just giving likes.
Pretty sure I could smell that here!Talking of smells. I dug out the cultivator from the shed for the first time in 35/40 years , cleaned the carb and filter bowl , new fuel and it fired up 2nd pull and ran perfectly but filled the garden with smoke for about a minute . The best bit was that I used to put a drop of Castrol R in the petrol and some of it was still in the system . The smell was FABULOUS .
View attachment 286591Made this yesterday fitted the timber today just have to paint the timber when I get some dark grey for it
