Where did you get the DXF's or did you do yourself?
Not after the weekend being called Joan.Nice work, but I hope they're going to be kept high up and for display, if little fingers get hold of those sharp pointy bits.....
And no, I'm not changing my name to @Parm![]()
Not after the weekend being called Joan.![]()
Cross dressing obviously, Slim?????
Dont ask!!! He'll send you a video link!?????
I will not.Dont ask!!! He'll send you a video link!![]()
So last week I put on the Hakansson blade, it didn't seat properly, ran off the wheels, and wouldn't ride right whatever I did, and started to crack at the weld before I'd even cut anything with it!Yeah they are. The last two I've had they snapped at the weld joint before they went dull, and there's nothing wrong with the saw or guides. They do work fine for a decent amount of cutting though.
This past summer has seen us cut a lot more steel than ever before, so going from 1 blade a year to 3 or 4 seems to make a difference on the pocket![]()
Like I say, we've always had good results from their blades and our imet does like a new blade. The cost is worth changing the blade out but we do tend to run ours into the ground. You'll be way below 5p a cut from a blade I would think.So last week I put on the Hakansson blade, it didn't seat properly, ran off the wheels, and wouldn't ride right whatever I did, and started to crack at the weld before I'd even cut anything with it!
The Harrison Saws blade came the next day, I wapped it straight on, no dramas, cuts straight and quiet.
Justbandsawblades (NLS Tools) were very helpful when I rang up about it, they said the blade joint should have been square but they did have a fault with the blade welder so they are sending another one out FOC.
@Brad93 I think I'll be buying from Harrison Saws from now on, the area rep was really helpful and their prices are cheaper than anyone else's, and if it lasts a good amount then happy days!
Whilst waiting for some Aluminium being delivered and after seeing @Fraserb plasma'd Santa I thought I would have a look for some DXF's
Came across a couple of Christmas themed ones so decided to give them a go, scaled them up a bit and here they are.
View attachment 316191View attachment 316190
Took a vid of Santa being cut, well a wee bit, by the time I got the phone out it was nearly finished
Got a new mechanism. To be fair the old one has had £28 worth of hammerTonights unscheduled maintenance. Disco drivers side window regulator. Its being needy again
View attachment 315928 View attachment 315929 View attachment 315930 View attachment 315931
