Is that why my brother's farts smell so bad when he has had chips?In my simpliistic view carbohydrates become hydrocarbons?........ I'll standby to be flamed![]()
Have to connect him up to the Ford Ranger
![laughing :laughing: :laughing:](/forum/styles/smilies/laughing.gif)
Well, my first failure. I changed the bed for the glass one but didn't change the settings so the bits fell off. Apparently it is recommended to have the bed set to 80 degrees for a glass bed?
I have set 70c for the first layer only, it drops back to 60 after that. I am using the Prusa slicer.As others have said 80 sounds excessive for PLA - one thing to think about is whether the top surface has actually reached a nice even 80 by the time it tries to print the first layers though, depending on glass thickness and heater size.
Edit to add: Ah I just spotted you were running less than 80 and have upped to 70. But the point still stands for whatever target temperature you're aiming at
Same, 40-50c for most PLAs, as the Tg isn't far above that.
I use the creality bed in reverse with a quick squirt of 3D laq.It is pla, the bed was clean as it is brand new. Levelled with paper but have no idea as to its weight. I have upped the temp to 70c to see if it helps and will report back. I may just put the original bed back on as that worked with no adhesion problems!
80c bed and 235c for nozzle. Worked well. Excess heat welcome this time of year70/75degC here for PETG.
Same for me but never used PETG up to now.60⁰c bed temp for PLA
80⁰c bed temp for PETG
I don't use a brim or raft, just a 3 pass skirt
Slicer is Cura
Glass bed, light dusting of 3dlac and away I go
Every few prints it will get a clean with hot soapy water if I'm in the mood, rinse well, air dry and it's good to go again
It's caused by an overactive fart gland I believe.Is that why my brother's farts smell so bad when he has had chips?
Have to connect him up to the Ford Ranger![]()
Personally I don't lower the temp out of fear of it causing detachment and just keep initial 60C throughout. I did run table too cool at 40C and used UHU stick glue. I think it was @ajlelectronics who put me right about using 60C a good while back.I have set 70c for the first layer only, it drops back to 60 after that. I am using the Prusa slicer.
Or Olympic..It's caused by an overactive fart gland I believe.![]()
I got the 3D printer with the sole purpose of producing casting patterns for metal.....then I dawdled too long. Still to produce one....Ah Well!I was printing with ABS for the first time at the weekend - what a faff. My Ankermake M5 has been fantastic on PLA and never missed a beat - I've had PLA prints fail due to my incompetence (not realising PLA needs to be kept dry, and that you can't just leave the spool to unwind) but the printer has never failed on it's own.
With ABS, though, I'd find that if it survives the first 4-5 layers while it's building the brim then the print will be fine but 2/3 of the prints end up as rubber bands before it gets there. Been going with 260/110 for the first ten layers then 240/100 for the rest. Results are good, if a little rough compared to PLA.
It's for a high(ish) temperature enclosure hence why I didn't want to use PLA or PETG, but the ABS spool will be going in the cupboard and hopefully never used again after this project!
That should say Ozempic.Or Olympic..
You need to make slurry out of Acetone and white ABS.I was printing with ABS for the first time at the weekend - what a faff. My Ankermake M5 has been fantastic on PLA and never missed a beat - I've had PLA prints fail due to my incompetence (not realising PLA needs to be kept dry, and that you can't just leave the spool to unwind) but the printer has never failed on it's own.
