eLuSiVeMiTe
thats going to be a big tray,
Tilt and slide...That means picking the machine up again
I could bolt mine through the tray then to the bench it sits onMine is on s stand like the one shown. Bolted to stand then stand bolted to floor.
I used to have a chester 25 I think it was, made a tray about an inch deep big enough to catch over spill from full table movment, sat the mill in it, on the bench and drilled through to bolt it down, I then just put a smear of instant gasket under it, using a pry bar all around. Bolted it down.
I shall take a closer look I did not see a drain well there was not a hole could be blocked up.Most mill tables have a drain in them to allow coolant to run down to the try. I actually have a hose on mine to drain it back towards the drain to the coolant tank.
All the Import mills ive seen have it in the back of the right hand side recess.
Thats all I have been using brush on coolant for now it does the job I need it to at the momentThere's no drain in the table on mine. I've contemplated drilling one, but I usually just apply coolant with a brush or can. I guess it's not really coolant in that case, just cutting oil.
I've also used a garden bug spray bottle with cutting oil in it when I've needed more of a flood, and just let it run over the table into the tray. It's messy and there's cleaning needed after, but sometimes needs must.
My Harrison Mill has proper flood coolant with a drain on the table, all the good business.
just need to find/scrounge something suitable for the tray!
Very posh is that it chip tray
