Blake's 7
- Ireland
I've finally received the final part of my DRO from Banggood. It has come in three separate packages a few weeks apart. I never have much luck with Banggood. Stuff seems to end up out of stock or never leaves China. It is rarely a quick or trouble free purchase unless it is a small cheap item.
I went for this model as it appeared to be the same one that Myfordboy from Youtube uses and it seemed OK for him. It comes with covers and fittings. I've switched it on, plugged in a scale and it seems to work OK. Just need to fit it to my Marlow mill now.
The tracking on the last package to arrive (The long scale) shows it was shipped from China to Belgium and then onto the UK. Maybe that's why I've been lucky to avoid any official interference to any of the three packages along the way. Might coming via the EU rather than direct from China help?
Acquired this Heuer vice from the rig we’re working on. The workshop is getting bolted shut and someone said if you need anything go ahead. There was a large 3ph Creusen bench grinder on its stand but 3ph and the logistics of getting it ashore was a no go. The vice came apart and went in 2 bags. 120mm wide with a 125mm throat and adjustable base.
View attachment 242965 Bought this on ebay, 18 inch. The vial is out by 1/4 inch... is it worth persevering with it, maybe even scraping the bottom face once I get the level set?
That’s a start. Mine used to start up fine, you’d start the arc, then the arc would extinguish and the overload would come on. You need to test it really.I finally got around to putting a plug on it and the three process LEDs on the front light up and stay on indefinitely as seen in the photo below.
Does anyone know the model number of it, I did a Google for it, but had no luck?
Adjust it. That's what the nuts on the right are for. Or give it to me![]()
The grout around the vial is dried out maybe ? I watched this a while ago, you can take the vial out and refit it and then have it calibrated.
Can't, at least not within the range it has to adust. The "insert" is loose at one end, and had something that looks like thistle mortar holding it in. Will have to make something to get it near correct and within adjustability range.
How much is a new vial? The markings are a bit grubby..
Two fire engines at my house
Oven set on fire when making lunchdare we ask?
No it was still ediblemuch damage?
Nah just need a new oven luckilymuch damage?
