Pigeon_Droppings2
- london
That square looks like the one I had for technical drawing classes back in the 1980s
A drawing board T square perhaps ?picked up this square today from freecycle, not sure if it was for making woodwork or clothing.
You stuck any leads on it yet and see if there is life ?
That’s a start. Mine used to start up fine, you’d start the arc, then the arc would extinguish and the overload would come on. You need to test it really.
It is a "Bosch Elektrohobel 1000W 0 601 590 003"
Put the 0 601 590 003 into Google and also look at images.
This page gives some other model numbers which may be closely related:
https://www.rivelferramenta.it/1609247005-CINGHIA-DENTATA-1-609-247-005-BOSCH-PER-PIALLA.htm
Exploded diagram:
https://ersatzteil-shop24.de/bilder/zeichnungen/bosch/bo-20201319-001.jpg
https://ersatzteil-shop24.de/bilder/zeichnungen/bosch/bo-20201319-002.jpg
the edge is just darker , i thought it was brass but still ok for a freebieA drawing board T square perhaps ?
Is that a brass edge set in the workface .. if so it could have been part of a Roto Ring drawing set where the pens had open ink reservoirs at the tip end , they were a common sight in a small drawing office in the 60's & 70's the brass strip set in the straight edge stopped you making an ink bridge between the paper & the wood .
The rubbing strip on the stock leads me to thinking this
these are what u need https://www.google.co.uk/search?sou...pObqAhUQ_BQKHZfwCzkQ4dUDCAg#spf=1595607235354I really like my pullsaws.
Get some funny looks at college using a dozuki to cut plastic conduit.
Customer hadn't seen one before until I was using mine a few weeks back.I really like my pullsaws.
great in winter aren't theyGot one of those as well.
Shatteringly so.great in winter aren't they![]()
Go away, go a long way away, then repeat.Best be asking Nell about that village pump , she stands by it apparently![]()
Might I recommend you take a look at Milwaukee Fixtec Nuts?Picked a new grinder key up from toolstation
Will be interested to see the guarantee
got to work to discover my boss had ordered the wrong flap discs...
