Kram
- Sussex
£4 delivered, fine grit bench grinder wheel. Ordered late yesterday and arrived a few hours ago, not well packed but rings true.
To be fair it’s more of the full thing than just a casing. Drill purpose and very much inert though!
Got a few stories like that but not for public forums! This one is very definitely drill purpose inertThere was a guy in the news a while ago, had some big artillery shell as a doorstop. Turned out it was live.
At this rate @8ob will be worried I'm taking money out his pockets!![]()
I've had a beer, any chance of a photo?
PM me the website please.. I'm on my last pair of spares .Dropped Tough saws an email and got 2 x 1/2" x 10/14 M42 for my Femi bandsaw @ 14.50 each and delivered next day. Quality jointing as well.
Some merchants are still doing great kit, service and prices
View attachment 339374View attachment 339375
The old oil boiler heat exchanger plate .
Two of the inter locking tubes one with the lifting eye . Note the open end is uppermost just incase it opened up a tad when I had a 6x 5 fence panel six foot up off the & floor blowing in the wind .
Excuse the mess I'm have a couple of mancupboard clearing days .. ( first time in 3 or more years ) .
I picked out the tubes & bits as I came to them
It's only set up with two vertical tubes .. The highest I've had them is nine tubes from floor plate to the top pulley hook /eye with my wife inserting the extra ones whilst I was on a strong stepladders holding the others together & lifting at the same time . The spreader bar is attached to the fence panel with 200 kg cheap ratchet straps , the pulley set is able to handle 250 kg ( IIRC £6.00 Amazon ) The line surprised me I was thinking that the 30 mtr hank would be cheap Chinese rubbish .. was very pleasantly surprised to find the internals were thousands of fine twisted fibres instead to the chines low budget stuff of a similar diameter that has a four inch wide random weave fabric & separates at about 90 kg . core inside the outer case.
As I said in the earlier post , I used a pair of 9 inch G clamps to hold a lashing bar to which the vertical poles are lashed centrally to prevent kick out at the bottom or falling out at the top or slipping sideways .
One lashing bar at the top of the posts and one at the base on the same side ( my panels sit on engineering bricks set on a cast in concrete cill betwen the concrete H section fencing posts ........stops weeds from next door , allow small creatures to move from garden to garden. Also to allow wind to blow over & under the panels to stop strong winds simply ripping them out of the H section posts .
I put the insulation sleeve over some 3 inch rain ware plastic tube so the protectors can be slid along the spreader bar for other liftings , It also helped stop the ratchet straps sliding off before I'd got them tightened.
PM sent DAPPH but for info its https://tuffsaws.co.uk/ or just email them on sales@tuffsaws.co.uk - told them what machine it was for and their best recommendation for my type of usage.PM me the website please.. I'm on my last pair of spares .
Have a search for log goblins on arbtalk, very funny read.Hardy likely, as he seems to give loads away, free gratis &nor nowt.![]()
I thought the plan would be leave it so he can help you finish itTody I acquired at least part of a nicely graded ground...
Question is can we finish it all before @8ob comes to visit?![]()
There response was pretty instant.
When asked when I'm going to finish the house my answer is usually about a year after I'm dead. I was joking but it wouldn't be if Bob was involved.I thought the plan would be leave it so he can help you finish it![]()
Harrison Saw BladesI've used Tuff blades for a few years and I can't recommend them
Never had a problem with the service it’s just they always seem to start stripping teeth from the weld no matter how careful I am.
I've tried the carbon steel and M42 grade in a range of tpi including the varitooth range.
Always try to keep at least 4 teeth in the metal, break the blades in and keep low pressure.
I try to keep a fine and coarse blade and change them over when required.
The saw is a 6 x 4 Hitachi which has rubber on the wheels and if I use “any” oil, the blade won't stay on, so I have to cut dry which I'm sure doesn't help.
The only way I can get any reasonable life out of a blade is by nursing it over the weld which gets old very quickly. I can hear / feel the join in every blade from new so it not an isolated problem (for me)
I've never worn a blade out, just end up with a section with no teeth and have lots that I need to join.
I now just try to cut thick stuff on the band saw which is ok because I have a chop saw which works better on thin wall stuff.
I’m now out of blades (again) and it would be great to be able to cut mitres in box or tube on the band saw again.
Anyone have a recommendation for another supplier?
NAD, really good equipment, but that workshop is well too tidy, shockingly so.Today I acquired a NAD CD player from evil bay
Sounds great with my old NAD amplifier and Tannoy 607’s which have been up in the loft for quite a few years.
The workshop now rocks! My wife says it’s too loud, she didn’t understand when I said that Dire Straits, Pink Floyd AC/DC, Elvis etc cannot ever be too loud
View attachment 339580 View attachment 339581
