Onoff
- Sevenoaks, UK
Sat 100 copper core and double-shielded cable is perfectly fine for reception and even Tx up to 400W if you work it out a bit.
Major advantage to that is it's dirt cheap, since it's made by the millions of feet every week, so you can afford to run it a fair distance by not paying the Ham Tax on 50ohm stuff.
Sat100 cable is as low loss as RG213 for less than half the price.
Avoid the steel-cored, copperplated, alloy shielded rubbish, as that's the most common sat cable.
I tried the scanner last night with just a long wire out of the window and soldered to a BNC plug pin. Scanned from around 68 MHz to >800 MHz and picked up just two garbled transmissions.
I think that manual you linked is for the same scanner but from a different region. Mine doesn't have the 30-50 MHz band for a start.
It's got I think 4m, Airband, 2m, 70cm and not much else apart from something up around the 8/900 MHz mark. No SSB. I recall when I first got it for Dad we could pick up some cordless telephone and mobile calls.
I'll likely just put this to one side for now as plenty of other things to do.
