I got what looks like the exact same Bosch QR set - you should not be disappointed
Did several 65mm holes in rail track web in a pillar drill!
Let us know your opinion on about it ?
Is it a Perkins engine with a delphi pump?FFS - just what I needed today.
2CX had trouble starting yesterday, sounded like a flat battery - put it on the charger and confirmed. Let it charge overnight and then put it on this morning. Still slow cranking over but coughed and eventually caught then noticed some oil on the windscreen then saw some dribbling down the exhaust. Killed it on the key.
Quick phone call to the ever useful @8ob who's familiar with these engines and given the engine oil level looked high we think diesel is leaking into the sump from either the IP or lift pump. Well it'll have to wait until after our holiday now. A mate down the road will bring a big digger up so we can lift the loader arms up out of the way - not that easy for access when you have two 1ft wide 40mm thick plates on either side of the engine
Beauty!
I'd have bitten his arm off too. You just don't get gear head drills for £50!£50
And it works
Didn't know I'd get a Swedish beauty for so littleI'd have bitten his arm off too. You just don't get gear head drills for £50!
No.My guess would be a failed capacitor.
Turn it upside down, remove the wiring plate and look inside. May have a bad capacitor, if so change it. While you are at it, fit a NVR switch.
