JOEPRO
- UK
Went to Kwikfit this afternoon to get the possible puncture fixed & the RHR new tyred wheel nuts check again as per the terms & conditions of the Motability scheme. good news no puncture .
The guy who did the check also did the new tyre last Friday he reckoned that the new tyre is more rigid than the other three so when it was minus 3oC the older tyres showed low pressures , all being 25.2 PSI , the ne tyre was still showing 35.2 PSI . so he adjusted the pressure with nitrogen gas & reset the tyre inflation monitor again for me .
T'will be an amusement if the three old tyres all have a slow puncture instead .
When was the last time you checked the tyre pressures?
I check my car tyre pressures monthly. And more often than not there are differences. Aka if you set them on a hot summers day then check them again when ambient temps drop then expect them to under read a little.
Now you suspect issues you need to check them after 24 hrs and a few days later etc to see is there a leak. (Obvious really but I'm sure 97% of motorists sadly don't check or don't know how to check their tyre pressures and just wait until a warning light comes on or a tyre blows out)
Get yourself a digital pressure gauge, or better yet a cordless tyre inflater with digital pressure gauge unbuilt.
