Memmeddu
- Italia Sardegna
When I've bought mine(k770 same as yours)I've done a research and the manual states you just need to flip the wheel washer upside to use either 20 or 25.4 mm bore wheels.because the sthil has a bigger bore and I don't have the correct spacerthe husky is only 20mm bore . And I want a 350mm blade not a 300mm
The manual also states it's possible to mount the wheel on the driving belt side to cut closer to the walls.
Cannot see how to be honest since it will spin the same direction and it would need a left hand screw which will not fit into the right hand threads.
Mines requires a new top end and a service kit .
I've attempted to get it started for almost an hour but nothing to do.
Compression passes through the rings and goes out from the carburettor.
It does produce a nice spark
Not sure about the decompression valve either since no matter what position it feels the same.
About the choke,I think something happens because if you pull the lever and eventually you put back in run position , you'll ear a click when you blip the throttle
