The_Yellow_Ardvark
https://www.death-clock.org/
- Going Away.
I have always been meaning to get a half decent grease gun as the normal style are just so useless.
Let us know how you get on with that one as it does look quite good and if it is I will likely get one myself.
I’ve already given it a go but by no means an extensive test. Rear prop on the Shogun as well as the top ball joints. The trigger is firm but easy too with no slop in the action. This is using Mobil XHP 222 grease which is thicker than most. Not sure how much grease comes out with each full squeeze of the trigger but seemed a lot quicker than the previous Sealey one. Then again that was useless and half the pumps of the handle produced nothing.
The grease nipple connector goes on easy and no grease escapes. The connector feels much tighter to get off and I thought it was stuck at first but just angle it to the side and it comes off.
The hose is generous at 18 inch, it looks thin but it is firm and still flexible.
Fitting a new cartridge was simply. Pull the handle back, insert the cartridge, fit the pump and push the handle in, pull out the handle and repeat, press the air release button (you hear a little hiss) squeeze the trigger about 3 times and grease is coming out the nozzle.
For £30 it feels very well engineered.
I need a few of thoseStopped by our local ALDI today and in the red tag offers they had 4500 kg Tow Straps for 99 pence each !!!
Also picked up a new Road Atlas.
.View attachment 189192 View attachment 189193
Didn't think you could still get a road atlas![]()
Yeah, and laughing out loud my Wife noted that the atlas made note of ALDI stores locations on all pages; smart advertising for sure.
I was surprised for sure, the hooks are worth more than 99 pence; there is also a plastic red flag and a magnetic sticker which states " ON TOW " included.
I went shopping yesterday and found this old hoe head, gave it a clean around potential logo areas and hey presto! It’s Whitehouse Bros of Cannock. This brand pre-dates Cornelius Whitehouse’s hedgehog brand. Very nice for $3, this will be from the turn of the century. I’ll clean it and put it back to use.
@Craig-SM mentioned about the grease gun he got the last day and said it was good. I have never been able to get any of the grease guns I had to work properly, they would work for 3 or 4 squirts then you would have to bleed it and the cycle repeated.
I used to have an old style one that was my dads that you filled with grease and it was great but inconvenient, I always regretted giving it away.
Ok so enough blethering, I order the grease gun last night and it arrived an hour ago so I put a cartridge in it and a few pumps and it was squirting grease 3m or more
Tried it on the profile rail trucks on the plasma and unbelievable, worked exactly as it should and I greased all 8 trucks and not an issue, never had to bleed it once. I have been on a greasing spree and have used at least half a cartridge up already and it is brilliant, amazing how such simple things give pleasure to simple people
The only downside so far is the strength needed to get the gun off the nipple, I pulled out a couple on the trucks as they are only screwed into the plastic ends but I found that wiggling it in a circular motion as I pulled it off helped and it does seem to be getting easier so maybe it will free off a bit.
Anyway grease gun here.
I also got a 1/4" socket set from Halfords and it seems nice although I haven't used it much yet.
Thanks, will have a look out for one.Hood they now make a quick release coupling which has a release tab like some tyre inflators to help stop ripping the grease nipples out.
Think I remember seeing them in mst a couple of months back.
Thanks, I think I will get one, could never get the normal grease guns to work very well, constantly having to bleed them etc.
You can get bolt head type grease nipple and a special slide on adaptor for the grease nipple . All you do is side the adaptor across the bolt head till it homes and slide it off when you have greased up .Filling a piston grease gun with out a cartridge of grease .
The way you fill the old grease gun is important . Do it in stages pulling the piston back 1/2" AT A TIME & locking it with the clip or the chain . Loading the grease with a spatula like making an ice cream cone up with soft iced cream , making sure you don't put air in the grease . Some times it's worth giving the reservoir body lower edge a gentle tap down on the edge of a table as you fill each level as this helps get any air bubbles up to the top .
Having a warm grease & gun also helps .. loading a grease gun at minus 10 oC with solid grease is not often very successful .
I've often seen guys try and use the gun cylinder & piston as a syringe and suck the grease in as they push the body into the grease... they never seemed to have much success as they were always having to bleed the gun.
