bigegg
- Leeds, West Yorkshire
To day I acquired extra heat in my mancave also acquired the knowledge that B&Q orange plastic buckets are very flammable . Next door but one has been having a day long smouldering bonfire , god knows what he's been burning but it ain't just wood .
I did couple of vertical MIG welds each about 25 mm long didn't realise the blob had dropped into a B&Q bucket filled with bits of Delrin off cuts . Turned the welder off to let it run through it's cooling cycle , turned the CO2 off , swept the floor , wife called me in to answer some questions . Decided it's not worth going back our again as it was time to come in for tea . I was about to close the garage door using the remote fob . Just happened to walk down the hall to see that it was still open and noticed 2 foot flames lapping up the argon cylinder & under the welding bench .. hobbled out as quick as I could , put the spray rose on the hosepipe & played Fireman Sam ( with an Yorkshire accent ) for a few minutes, mad sure the argon cylinder was cold . Then used a spade to shovel the mess out side and ensure it's totally stone cold .
It was then that I realised hardly any of the orange B&Q bucket was left , there were still lots of very thin strips of Delrin that had hardly bubbles up , one or two 15 mm thick bits that were well melted .
Ok obvious mistake the bucket should not have been near the welding bench , not so obvious ….. the flammability of the orange bucket . Others bonfire smoke can dull you into a sense of false security when you're welding or grinding .
Lesson learnt , I live to fight another day . Now off to give it it's final check an hour after the event . Then start cleaning things up .
lucky escape!
