Not bothered anymore.I don't know if I would be that worried about it just randomly catching on fire (not in your shed anyway) some sensible precautions like close monitoring until it proves reliable is my attitude. I wouldn't build an enclosure but something like those heavy PVC (?) curtains as seen in the PRUSA factory tour is definitely on my list.
It's only 240C or thereabouts, very few items will combust at those temps so it's no different to any other electronic item in that respect. Smoke alarm wouldn't be a bad idea, in fact speak to any fire officer and they will give you a right ticking off for not having them everywhere anyway.
It doesn't mean I won't be taking other precautions though@brewdexta Interesting. Thanks for putting me right.
I screwed up one of the nozels when I first tried to the level the bed with the z axis limit switch too low.
I did exactly the same the very first time I switched mine on! Bed way too high, nozzle scored a right angle mark into my brand new top.
Am sitting offshore on weather standby so have plenty of free time on my hands, video below is how i would go about drawing this part in fusion. Hope it helps, tried to not use shortcuts so you can clearly see what commands i use:
- start a sketch
- choose what plane you want it on
- choose rectangle
- Fill in dimension for the one leg of the rectangle
- Use tab to jump to the dimension box of the next leg of the rectangle
- place a circle anywher, don't worry about the dimension
- place another circle
- use the dimension command to dimension the circle diameter and their position on the drawing
- draw two lines making the legs of the slot
- use the tangent command to make the lines tangent to the circle
- finish sketch
- extrude the sketch to desired heigth.
Screen recording of me making the sketch:
Do some youtube tutorials on sketching and sketch constraints as it is the basics of everything in Fusion, once you get a grasp on that the rest will follow.
Dont you have to select a box to get an actual thread?Oh well, all done, waiting for the printer to warm up. FWIW it is possible to select, move, rotate etc. even though the interface is incredibly awkward. I'm sure there's a good reason it is so damned difficult, probably due to the depth of features it needs to support.
What is less forgivable is that unbelievably, in Fusion when you select your carefully chosen cylinder go through the rigmarole of creating a thread, the default behaviour is to make that thread a texture map. That's right; it assumes you want a picture of a thread rather than an actual thread form!
Is there a reason the centre oval is hollow. Could you not fill it in with 10 infill and then print it with the thread one mic hole to the bed?Need to work out a way to reduce the supports else I'm reasonably happy with the prototype.
Needs more fillets, rubbing down and possibly acetone vapour smoothing. Also should run a 3/8 16 tap down the threads. The support struture is onearea I need to try and reduce in all these models. Need to spend more time in Cura I think.
You should need no supports then.
That's normal in most cad programs that assume you're designing, not machining straight from it. Otherwise you create an unbelievably huge amount of geometry and on any reasonable size assembly your computer crawls to a stop. And even with most machining work you don't need the thread geometry in there because you just use the feature to call for a tapping operation.
There’s a tick box that creates an actual model of a thread and not merely a picture. I assume it’s for old fashioned CNCwhere you’d most likely call for a tool change and a tap.
@Screwdriver
Your original mockup before rotating the centre, does that oval have to be oriented at 90?
If not you could have printed that without supports, unless I was going for authenticity I always try and modify to suit what works best/ easiest on the printer. Supports waste plastic and printing time and need cleaning up.
Just my thoughts.
most failed after 2 to 4 years!Not bothered anymore.
I was rehired for 6 months after I retired with 32 years service.
I was running the Brigade Home Fire Safety Checks for my last 3 years and they wanted me to hand over in the 6 months.
Sadly we had a New CFO who needed a personality transplant and for a bit shirty when I explained his policies were undermining our last 10 years work......sadly no one wants to sponsor (pay for the alarms) so God knows what is happening as most of the Alarms had a 10 year battery life....although most failed well before then.
