daedalusminos
- Norwich
What's the material?
varying bed temps 70ºC - 85ºC, nozzle 240ºC - 245ºC
That's what I use for PLA and acetone/abs slurry for ABS Pro.My lad just did a little ABS print just using 3D Lac on a borosilicate glass plate(don't ask how much) clipped atop the Anycubic Ultrabase. Came out fine, no enclosure either.what I u
Happy with it overall? I'm very tempted to buy one for home useI've got a prusa and I suffered from a lot of unevenness in the bed. As if the surface was warped all over with random hills and valleys
Yes, the Mk3s (I think there's a + version now) has mesh bed levelling, I have absolutely no problems printing over the entire area.Does the prusa probe the bed to get a surface map?
Have you tried cleaning the nozzle?This one is a heartbreaker.
Nice looking part for an art installation. Client wants transparent/opaque so I bought a new reel of Filatech. After some experimentation with temps and bed height etc. four and a half hours later:
So I multiply the item to leave four more to cook and...
Nope. First layer will not stick. Those little round cutouts are the culprit. They ping off, jam up the nozzle and drag everything off the bed.
so I try again
And again
I won't bore you (any further) but eventually by early morning after an all nighter, I thought I had it nailed.
Nope.
Too risky if one fails they all fail. So I bite the bullet, edit settings to print a raft and go for one at a time.
Have to babysit the print until it gets past the danger zone which takes ages with a raft. Finally retire to bed.
Next morning all excited, find this.
Not a grat start to Sunday and it looks like it got way past where I thought it could possibly fail.
Looks like 4-5 layers into the actual part.
There must be an issue with this filament because I have never experienced so many fails. Tried glass bed, fibre bed, varying bed temps 70ºC - 85ºC, nozzle 240ºC - 245ºC, pure IPA wipe down, pritstick glue, can't get it to stick.
Anyone have any more suggestions? I have already destroyed the OEM fibre bed. Excessive cleaning off the glue and I cut a gouge right through the middle. Glass bed only from now on.
