DAPPH
as dyslexik as I'm daft
Put a venting hole about 3/4 of the way up the side of the printer enclosure , Put the extract fan & housing on the outside of the enclosure the printer sits in take a 1.5 " pond pipe through the wall to the outside , making sure it is at least 500 mm from any opening , window o trickle vent vent
You can easily print workable hood/ enclosure for both the enclosure and the external wall holes on both sides . Then if you chose to you can slip the HEP filter inline between your printer enclosure and the outside wall.
I'm treating the vented fumes from my Prusa printer similar to the requirements for a gas or oil fired balance flue boiler .
I suppose I'm fortunate in that I can vent the enclosure's fumes direct into the garden area some 30 mtrs from the bungalow & as I have no neighbours in close vicinity to the outlet .
