Migmac
- Kintyre. Scotland
They’re a good looking saw
only thing is the plastic er are they called scabards? that dig into the log when cutting?They’re a good looking saw
Felling spikes/dog bars, don't know what the official name isonly thing is the plastic er are they called scabards? that dig into the log when cutting?
even my plug in saw has metal spikes!Felling spikes/dog bars, don't know what the official name is
(Scabbard is the plastic cover that slides over the bar)
Dont use that ****e in it!
Get some fully synthetic or it you really love her some of this,
If you remove the bar there's 2 unused holes which look like they're for mounting a set of metal teeth. I thought about making a plate to fit mine but on a small saw like that they're not really neededonly thing is the plastic er are they called scabards? that dig into the log when cutting?
Dogs. I take all mine off, even on the big sawsonly thing is the plastic er are they called scabards? that dig into the log when cutting?
Does it not have extendable legs for stability most vehicle mounts???What powering it from a seperate vehicle or replaceing <2 tonnes of vehicle with 2 tonnes of ballast?
How come you remove themDogs. I take all mine off, even on the big saws
An interesting method/way of usage.
If your boring into big trees, you loose depth of cut due to the dogs. They’re meant to make cross cutting logs a bit easier for the operator
Because that's extra expense and theAn interesting method/way of usage.
Why not just install a largest Honda stationary engine with hydraulic pump, instead of having to connect the 110?
That's what longer bars are for![]()
