got quite a few erbacher heater hanging around at work they tend to rock up on stuff fitted with deutz engines
a common figure used is 20 to 25 K BTU which I think is about 6Kw
but that room isnt traveling at 70mph, with the air being drawn in and taken from outside at what could be minus 10 and then heated immediately to the hot air you feel from the vents to warm you or heat the single glazed windscreen ( and all the other windows in the car) which takes up 50% of the area of a car, then there is the 500 watts ish for front and rear screen heaters.
the 5kw at home is recycling the air in the room not heating it from outside them blowing it back out of the rear as a car does to prevent condensation.
these are tiny heaters to just really demist windscreen for competition and are 3.5kw
https://www.demon-tweeks.co.uk/motorsport/cockpit-ventilation/demon-tweeks-lightweight-heater
The heater matrix is not big enough to shift that sort of heat.
Ditto Puffernutter, if you come across any spares let me know as I need one for the machine shop (an possibly rig one in the camper van later).
Cheers,
MM
No, cars have breather valves at the rear and under the floor to let air out constantly you should be under one in the pit when the heater is blowing you get a loverly warm blast through pipes in the floor etc but the main escape are through the rear breather vent flaps YOU have no control over VVVV they just blow open and let out all that damp air from your lungs etc but are usually hidden in bumpers C posts etc etc there is a considerable fresh air flow throughout the carthere is somewhere to go which is typically outside the car through the windows.
Yes. The manufacturers are spending the budget of a small country economy developing car windows to retain heat.....
As You mentioned the fan and shifting heat you where obviously meaning the air would travel out through open windows ,I was making the point that the air travels out with no control from us, now if you could make glass that the air traveled one way ie out but not in at the same time as retaining the heat then that would be expensive methinks,The fan / matrix can shift the heat easily enough provided there is somewhere to go which is typically outside the car through the windows.
oh yes it is, dont forget you have a massive fan blowing through it, for example does the fan in your home 3kw heater make half the noise of your car fan on full---- NO that is because it is only moving a modest amount of air to cool the element of 3KW Now if you had a car heater fan blowing through the 3kw element you would hardly feel any heat at all , because the 3kw would be lost in the masses of air, you have close to boiling water passing through a small rad getting masses of air blown through it to efficiently remove that heat and drop the boiling water to 50 c nearly half, A heater on full can keep an engine cool --------sometimes too cool in fact, many times the actual cooling rad is not circulating hardly any water in minus C conditions.The heater matrix is not big enough to shift that sort of heat.
