So the feed doesn't slow yours down?
The feed settings do something, but i think it moves through the sides of the box too quickly.
dazza
Could you put up further pics to show what & how broken ?
Don't understand the scouring & stress cracks
Not good if as you say came back with 1 speed + other faults who did you buy from
Watching that vid you posted Kim the saw just cuts under the weight of the bow. There is no damper or feed control it just rests on the material and cuts through....
Mines the same. I can get away with a courser pitch since I fitted a damper on the bow I have full control over the speed it's fed through.Maybe they are not refined enough or maybe you just have too course a pitch for thin stuff.
I can get away with a courser pitch because I have infinite control of the downfeed but I still have to be careful as the blades I normally use are 5 to 8 Vari pitch so really more suited to slightly heavier stuff.
Ordered the NG120XL. With a spare blade and a deburing tool they do. Super excited. Plasma cutter tomorrow hopefully and the Saw at the end of the week
Yeah, he said the abs one is more designed for machinists. Cutting solid steel not box or tube. He said the one I ordered cuts unbelievably quick anyway so not really needed unless I'm wanting to waste cashSo did Stakesy's reckon it was better for your needs than the ABS one?
If in the future you decided you could benefit from a feed control then it is fairly easy to do, even an air cylinder with a needle valve and a one way valve would do the job.Yeah, he said the abs one is more designed for machinists. Cutting solid steel not box or tube. He said the one I ordered cuts unbelievably quick anyway so not really needed unless I'm wanting to waste cash
I doubt I will to be honest. I won't be doing enough to need anything like that.If in the future you decided you could benefit from a feed control then it is fairly easy to do, even an air cylinder with a needle valve and a one way valve would do the job.
Motor cycle steering damper.If in the future you decided you could benefit from a feed control then it is fairly easy to do, even an air cylinder with a needle valve and a one way valve would do the job.
New toys. Wahoo.Ordered the NG120XL. With a spare blade and a deburing tool they do. Super excited. Plasma cutter tomorrow hopefully and the Saw at the end of the week
I have thought about it for ages. And was gonna do some videos before the landy went but I accidentally deleted all the footage and got irritated.Very nice and shiny I can't wait for the test reports!
You should do a YouTube channel - you would be so popular. A refreshing change from most of the welding videos I see. And you would get loads of sponsorship and free toys!
I would love to do my own but I am too ugly and the Welsh accent wouldn't go down so well........
Wrong. Already tried the chopsaw. I need to refine it. I may do a video on that tomorrow maybe if I can pluck up the courage.@KimB So, which of the new toys gets tried out first? My bet's on the plasma......![]()
