Screwdriver
Cheers bud. I am going to let your other one finish and run this one tomorrow . Thanks again.Curtain bracket II @ukracer
Fusion 360 isn’t the tool for editing STLs. Meshmixer or 3D Builder.Ok guys maybe a bad time to ask but hey how.
I need to increase the exterior wall thickness on a bracket.
It was designed for a 30mm rail so I rescaled it to fit a 10mm rail.
This has meant the thickness is too thin and it snaps on the bend.View attachment 324725
How do I increase the external size in cura.
Meshmixer is a million times worse to use (for me anyway) than fusion and I find that hard. I will check out 3D Builder next week as I have some time. But not in my workshop.Fusion 360 isn’t the tool for editing STLs. Meshmixer or 3D Builder.
@ukracer
Files uploaded to Thingiverse
Right hand rack holds a mix of Kennedy and SnapOn combination spanners from 6mm to 20mm in 1mm increments
Spanner Rack - Right Hand by indy4x
Spanner rack right handI designed this to go in the right hand side of the spanner draw in my roll cabIt is drawn to hold 6mm to 20mm Kennedy Expert/SnapOn combination spanners in 1mm incrementswww.thingiverse.com
Centre rack is for 10mm to 14mm SnapOn medium length and 10mm to 19mm SnapOn short combination spanners
Spanner Rack - Centre by indy4x
This was designed to hold Snap On combination spanners from 10mm to 14mm in 1mm increments and SnapOn short combination spanners from 10mm to 19mm in 1mm incrementsIt fits in the centre of the spanner draw of my roll cab and compliments the LH and RH racks that hold the rest of my spannerswww.thingiverse.com
Left hand rack is for Halfords Advanced brake pipe spanners in various sizes and ratchet spanners from 8mm to 19mm in 1mm increments
Spanner Rack - Left Hand by indy4x
Spanner rack to hold 2 types of spanners so it is specific to my collectionAt the front of the rack is a set of Halfords Advanced pipe spannersThen a set of 8mm to 19mm Halfords Advanced ratchet spannersIt is intended to go in the left hand side of the spanner draw in my roll cabIt compliments...www.thingiverse.com
I alternate between Amazon and Ebay. Amazon for choice and Ebay for the more everyday stuff at lower prices.Can anyone recommend a decent website which will supply a wide range of filament materials/colours etc?
Ta
Www.3dqf.co.ukCan anyone recommend a decent website which will supply a wide range of filament materials/colours etc?
Ta
Neither is gullible.I tried to look up the word " esoteric " in the chambers dictionary but couldn't find it .
You have to look under oranges for that , if you say oranges slowly it sounds just like it apparently .Neither is gullible.
Do you upload the StLs anywhere mate?The Henry crevice tool. It has been printed and seems OK. To get the fitting accurate, I used a hot air gun to soften it and then attached it to the hose to get the perfect taper.
Yes, I upload to Cults 3D and Thingiverse. The former gets my new designs though.Do you upload the StLs anywhere mate?
I need to sort my suction out next year.
