Woody.v8
Blue gluer
- staffs
No impact driver, A slow impact from an air gun or similar.My first post on this thread said use impact driver
I have defrosted copper pipes for metres at a time using a stick welded by making a perfect connection to either end and applying the power which heats up the whole length of pipe without damaging the pipe.I think you are the joker expecting that to travel 75mm deep
To use an impact tool with a socket, the socket would need another nut of the same size to pack it out or the impact from the outer rim would strike and damage the headMy first post on this thread said use impact driver
would like to like this twicenot to sure on the chemistry of it, it could be that the expanding bolt compacts the rust slightly leaving space for it to move
The heads on the bench!To use an impact tool with a socket, the socket would need another nut of the same size to pack it out or the impact from the outer rim would strike and damage the head
you old smoothiewould like to like this twice![]()
the thing is it does work and has been used by plenty of us on here, and has worked when heating the external of the component has failed
well the top of the block then! but you know what im getting at?The heads on the bench!
well it would seem there are quite a lot of us that have successfully used this method and only your lonesome self saying it wont work.I will enlighten you.
You have to heat the outer surface ie the aluminium as aluminium expands more than steel "coefficient of expansion " that is what breaks the bond not heating the stud
It's a fair point and yes if you want to remove a steel nut from a bolt you warm the nut to expand it. In this case you can't warm the whole Alu head........ But think about it you are doing this. The Alu will as we agree suck the heat out of that glowing stud, it will also hold that heat well due to its conductivity. And there for we are heating the head too (indirectly) we don't need to get it that hot to start expanding remember it melts at 600degree C. It will expand a little and a little is all it needs. This is why it works.I will enlighten you.
BTW you didn't enlighten me![]()
I could do it time and time again and the weld would never fail.Maybe you could show how this would work on video.
You select a 10 mm stud weld a nut on the end.
You fix the stud securely and shear the stud without the weld failing.
I will look forward to seeing the video
now your just being a little silly, if I were to take a 10mm stud and try it of course it wouldn't sheer the stud (ive never tried), but the fact the stud sheered whilst on the engine is because the head gasket leaks and corrodes things.Maybe you could show how this would work on video.
The weld will not fail....... Your point is valid though because the heat generated by welding will make the studding weaker so it will break easier than the original bolt but unlikely on the weld. However as I've said it doesn't need to be as strong it will come out easier with the heat.Maybe you could show how this would work on video.
I don't intend to keep replying back and fourth, if you don't think the method works then fine that's your choice but as I said earlier there are quite a few people here saying it does, maybe we are all wrong and was simply an illusion when we did it who knows.
