Revs1972
- Torquay, UK
You mean beams not columns and why are you using UC'S for beams?
Why not ? You can use UB's as columns too you know
UB's as columns is quite common, its used regularly on agricultural buildings as you only need to buy one kind of steel and the bending loads in the columns are similar to those in the beams.Why not ? You can use UB's as columns too you know![]()
There is a 10x30mm strip to be attached to the face side of this edge..I am in hope it pulls the dog leg out.if it don't it can snag in the runners I have yet to make.That's being hyper critical. Is it that important?
Well for the last two days its been modifying a MB Unimog, it now has an uprated alternator, replacement upgraded hydraulic pump, new hydraulic feeds to the front and rear AKA agricultural spec, new hydraulic tank, larger hydraulic oil filter, and a new fuel tank arrangement leaving the new stainless tanks higher off the ground for improved ramp breakover angles and undertank protection to this takes the impacts instead of the bottom of the tanks.
I did ask a silly question which was "are the tanks empty" which got a response of him taking me to the offending tank and telling me to look underneath where I saw a piece of tree branch sticking out of the bottom of the old tank.
New pods were made for the new rear lights which are now recessed LED items complete with rear light washers, well, most cars have headlight washers these days.
We also fitted a second hand 20 tonne front winch which is detachable.
Couldn't sleep. New medication.
Steroids, by any chance?
I got board, I had coffee, after beer.
I had a welder, I had scrap metal, I had more coffee.
One broken Astra rear spring, horse shoes, old core plugs and some odd bits of bar and a coffee.
One Bumble bee, flowers are already made, just got to move them.
Looks good but how did you weld the coffee??
