selectedgrub
- New Zealand
View attachment 269518 View attachment 269519 View attachment 269520 The current dwellers tracked me down to make another gate,short fence and arch,to match the ones I did in 2002.
Need to touch in that masonry!
bet they have a terrierNice work.
Whats with the double bars at the bottom of the gate ? Not seen that before.
Pretty sure it's flat but will check tomorrow.
Common round these parts,iirc,the previous dwellers in 2002,may have asked for this on the other 2 I did,I like to divide the height into thirds for proportion.glad you like it.Nice work.
If I need to do a heavy job I can always make another one.
Today's follow up to post # 14252.
First one, the yellow track is the first [straight], then the red which is deeper and shows the skew
So, turned the work-piece over this morning and cut this, taking three x lesser cuts
Then, dropped the cutter and produced this on the same track - at the end I turned left and moved along the X axis in a oner, and this is the result - well pleased now. The depth of cut ended up at 1.9mm[a random test depth]
So, the answer to the problem? 1. Ensure your cutters are sharp 2. Lock off the Z axis while milling3. Learn patience, and feed appropriate to the job - material/cutter size, type etc. 4. Repeat the foregoing 5. Use lube
[behave, now...
All fairly basic stuff really, and some schoolboy errors compounding the exercise.
Happy days, I'll have more confidence in what I'm attempting now - although I never had any problems with a work-piece firmly clamped in a machine vise.
