eLuSiVeMiTe
I know what you mean about the Myford fitting one. I used mine for the first time making my 1/4" BSW dome head screws and I was surprised at how inappropriate the design was. It's a good idea but could have been done much better so you can work closer to the chuck. When you said 'filed it away', I thought you meant you'd filed bits of the original to make it fit betterThen it was a case of giving it a go:
This has been on my project list for about 10 years. About 5 years ago I decided to just buy one and I bought one that was designed for Myfords. It didn't work very well with small diameters as you had to have a big stick-out from the chuck or the chuck would hit the body, so I filed it away with the idea that I'd think about it some other time....
Me too, use my size A copper/hide all the time, I've been meaning to make myself a deadblow equivalent for ages, might finally get around to it soon.Wish they did these as deadblows
Lead hammers are the absolute best.I was given this Thor hammer the other day.
Been after one of those mould / bowl things for years.Lead hammers are the absolute best.
We made a mould at work for making 4kg-ish hammers, we go through around 20 a year for both production and engineering depts. Used to cast lead on site but eventually subbed it all out as it was easier than bringing everything up to scratch from Parm's HSE point of viewBeen after one of those mould / bowl things for years.
Keep looking on eBay…..
Looks spot on mate. Cheers
Not got a reference, but a bit of pythagoras gets you 1.3mm as the depth on a 1.5 pitch 60° thread.A nut.
Threading on this took far too long. Anyone know a reference for internal thread straight infeed distances? I was expecting 0.7-1mm but ended up at 1.4mm, 2.96mm on the diameter dials. The test thread worked, would have stopped far too early without it!
For manual lathes with a compound this makes the most sense... Easiest to calculate, and easiest to cut as well. I've had my compound set at 30 degrees permanently since I set it up lolAnd if you go in at 30° it'll be 1.5mm, as a 60° angle triangle is equilateral.
