Are they made of rubber?What are these? I'm tempted to throw them but thought I should check first. They were mixed in with some other bits I bought.
They are hard, not rubber.Are they made of rubber?
They look a bit like push in feet for instrument/"project" boxes?
If so, and they're no use to you, I'll take em off your hands?
<edit> they could also be filler bungs to fill a counterbored hole whilst something is being painted?
Try bearings r usFinally got round to ordering the bearings and seals for the reduction gearbox to go on my metal cutting bandsaw project - £50 for three bearings and seals, Simply bearings. Trouble was I'd written it all down way before Christmas, but life got in the way and I lost the bit of paper I wrote the details on...
From memory they were less than £40 then...Pics when they arrive!
Not magnetic. Possibly ceramic.Magnetic? Ceramic?
Found some similar items. I don't know if the code means anything.Magnetic? Ceramic?
They look like vibratory tumbler media, at least in terms of colour/finish, but I've never seen it in the first shape you found, and there's no reason to have such a small quantity of them, you need a bucket full to be useful.
Jammy jammy git!The dividing head got a bit of TLC today, in the form of wire brushes and wire wool dipped in paraffin. I was really pleased with how easily the various fasteners came out. It'll probably benefit from a bit more detail work at some point, but it'll do for now. Given that I won't be able to use it until I've got a MUCH bigger milling machine, I just wanted to get it a bit more presentable and oiled to protect it in the meantime.
Some before-and-after shots:
Does anyone else on here have one of these dividing heads? If so, I'd be really interested in some details/dimensions/photos of the sector arms and whatever method is used to hold the (screwed-on) chuck in place against milling forces (i.e. to stop it unscrewing).
Metals 4 U will have many 24/7 customers so only need bulk varied sizes as top up stocks to replenish , I suspect your local guy only sells in working hours & will only buy in a few at a time rather than hold a large varied stock , plus Scotland is expensive because of sparse population & long distance haulage away from a couple of cities & rhe rail network .5700mm x 25.4mm x 2.6mm CDS
£78.81 + shipping & VAT! (metals 4 U)
Still less expensive than buying locally, which I can't get my head around
Goodness knows how you professionals charging a customer deal with prices like these? Do you pass on the increases / overheads?
Do you ever take our the old Formica covered thick ply tops . Where you could cut four 9 inch wide x 30 inch long strips off it ?Today I acquired a new kitchen
As usual I'm photo-documenting the process so will put a thread to show the progress
Maybe, although the local supplier (Govan, Glasgow) is pretty big and he keeps loads of stock. At least, it looks a lot to me but maybe not in the grand scheme of thingsMetals 4 U will have many 24/7 customers so only need bulk varied sizes as top up stocks to replenish , I suspect your local guy only sells in working hours & will only buy in a few at a time rather than hold a large varied stock , plus Scotland is expensive because of sparse population & long distance haulage away from a couple of cities & rhe rail network .
