Dimitri De Spiegeleer
- Belgium
Aluminium guttering does not fall under EN1090.
			That's a bit of a sweeping statement, just because you are not signed up to EN1090 does not make you a cowboy, there are a huge amount of competent fabricators who have had this regulation foisted on them by Europe. I guessing if you had a poll the majority would not have wanted this.Kent will still be trying to get out of it, so he can make the structural steel buildings for his mate. I'd link to the post/topic but can't on Tapatalk.
From what I've read, all welders that have anything to do with the finished product need to be at the same level, coding, etc.
The idea of EN1090 is an attempt to stop the cowboys in the industry.. Jump on the band wagon and embrace it, or play cowboy elsewhere.
Thanks for the clarificationAluminium guttering does not fall under EN1090.
Yes I see what you mean, don't think I'm making my point well enough lol. All I mean is before this 1090 came in, generally a coded welder made more money than a non coded welder, even if the non coded welder was just as good. So I was just trying to gauge if people thought that this may push wages up really? Hope that makes a bit more sense.Why is it hassle? If they work for a company, the company will be picking up the tab for the tests, materials, and lost labour, surely?
It's not as if there are bridges and buildings falling down across the country. It's just another level of bureaucracy bought in to leech money out of fabrication companies.
It's going to hit the small businesses hardest, sole traders and the like who will struggle to find the time to wade through the compliance and not able to afford advisors to help them.
Who will gain?
The large companies who will have less competition so can put their prices up, add in the cost of compliance and steelwork just got a whole lot more expensive with the regulators taking there cut!
Who will gain?
Kent, what do you mean by it's not a proper coding?
If the welder has passed a test to BS EN 287-1 (or equivalent) and has welded the joint to a proven qualified Welding Procedure then what else is there to do?
The welders in regard to EN 1090 exc 2 and and above have to be tested to EN 287-1 and all of the welding proceedures have to be qualified.
no probThanks for the clarification
At least with this new regulations it means that some company would find it extremely hard to start importing Structural Steel from India or China or South America, which should hopefully mean that rates and prices remain worthwhile in the UK.
That's the whole issue, people put too much stock into the word "coded" welder. It only means welding a particular joint to a given proven standard. Nothing more nothing less. You can only weld the joint in front of you to the standard specified by the client. Just because the test is carried out at your usual place of work on machines that your used to using is semi irreverent, because the machines should be calibrated and also the parameters required to successfully weld the joint are given in the WPS, they are not decided by the welder himself.
The whole Brussels debate is for another time, but I know for sure that a lot of very large Structural Steel Fabricators in the UK, also export a lot of there yearly tonnage to other projects based in other EU countries. So regardless of if the EN 1090 law applied in the UK, they would still need to be accredited in order to continue exporting.
Finally, being involved within the welding industry for my profession, I don't see why its so wrong that a bit of "professionalism" is being bought to an industry which was up until now pretty much completely unregulated. It's only now more in line with Tank and pressure Vessel manufacture.
I'm very sorry for the position you are currently in, but - being belgian - I don't quite understand your anger towards Brussels.
This entire story is coming from a European workgroup, with representatives from each country. The meetings are always held in different locations, at least one meeting in the country of each representative. So there are bound to have been one in the UK, as there were brittish representatives as well. Brussels doesn't have a significant meaning in this story, it's merely one of the locations were those meetings were held.
True what you say, a "coded" weldor doesn't exists, each certificate is very specific and has a limited field where it's applicable.
One man bands are having a rough time, also in Belgium, where several small places (father and son, two brothers, ... , those kinds of firms) were forced to either close, or to work together.
I currently am helping a company that is made of six small local firms. By carefully choosing the WPSses and the PQRs (to minimize the expenses), and having one guy follow the RWC course (so they can work independently in the future), they're off to a very good start.
It must be said, they have a great welding coordinator which helps a great deal
Now might be the time to engage in a new start, merging with some fellow companies?
no prob
I can see Kent's point, I know personally 2 small fab companies close to me that are debating whether to call it a day, highly regarded but not able to comply with the regs without massive time and cash inputs which they just don't have. We are talking about the livelihoods of highly skilled men who have done nothing wrong apart from being too busy to wade through the compliance and run on small margins so cannot afford 'fee charging' advisors, it's a very emotive subject.What is one of "them"? To be frank I find your replies to a fairly new member who has only ever tried to help other members understand the whole En 1090 debate quite rude and pathetic.
