Guineafowl
- Nairn
He’s right - might be worth a shot. Impulse of force: imagine trying to push a nail into wood with a hammer, versus banging it in normally.I can't see that being better than a 10 ton press ???
What I can't follow.is the tool you rented what did you use that for? As I thought you said you needed a bigger impact gun.Just to elaborate... this is the brand new cv joint that only went so far before jamming solid I can't budge it forward or backwards. I have hammered and hammered with a very large hammer but it will not move. If you read this whole thread I could not remove the original cv and ended up cutting it off and was left with the spider and I had to cut that off too.
I'm hoping I can get this pressed off somehow .....
Ok that makes sense to me now.The tool is a cv joint puller it works by clamping on to the drive shaft and then a large nut tightened to the thread of the cv pulls it off the shaft ... my impact gun couldn't do it so hired a bigger one but that couldn't budge it either now even wacking with a fbh isn't working....
I think I would bite the bullet and cut the new joint off the shaft it's probably going to be damaged now anyway, buy another new joint and carefully check fitment of the spines now it's on the bench
