charlysays
- UK, Wales
I always love when people get the rose tinted glasses out, about how modern stuff isn't as good.
We also have far better fuel economy and emissions.
Off course you could go to chain drive which means you need to compromise valve timing to allow for chain wear (belts don't wear, so timing remains the same between replacement).
Or you could go back to side valves, or have enough valve/piston clearance that compression is that poor the volumetric efficiency is horrendous.
There was a reason behind that setup. I can't quite remember the details as it's been several years since I covered it, but IIRC it was to allow faster warmup and a more stable operating temp. The biggest flaw with that engine was the rubbish head gasket, and it was prone to coolant leaks, not the thermostat.
That rubber belt is far more efficient than a chain. It allows more precise valve timing over the lifespan of the belt, as the belt doesn't wear.
And it's not as though timing chains are infallible. I've seen plenty chains fail.
Off course some people would love to go back to the "good old days" of cities turning black due to soot with the smell of hydrocarbons hanging in the air, having to service their car every few thousand miles, always wondering when it'll breakdown next.
Lets remember pre 90s, how many engines ever made it to 80k without needing major work?
New is worse though if you like to be able to repair everything (almost) yourself and/or don't have much to spend on buying a car.
90's was the pinnacle really for reparability, long term reliability and rust resistance. After 2000 it seems like car makers have deliberately tried to make cars a disposable item which are not likely to even survive long enough to become classics. It's still fairly easy to find 90s Peugeots for example with no visible rust and few if any structural problems, still passing MOTs with huge mileages. With many 90s engines it was possible to de-electrickery them (I remember binning the lucas IP on my 1.9TD peugeot and fitting a bosch IP which just need a switched 12v live to open the stop solenoid to run, nothing else- it even kept going when the alternator died!). On my C250 TD I've pretty much made the engine standalone now, it still runs an ECU (of which I've got several spare immo off ones) but with all extraneous stuff (electronic turbo control, etc) removed including the immobiliser.
I think there's a compromise to be made between emissions/ modern convenience and reparability- currently there's almost no balance at all with many cars. Even if the engine needs all sorts of emission control on it there's no need to have the indicators controlled by a computer, or engineer it so it's a nightmare to do relatively basic routine stuff like cambelts or timing chains. We have all the benefits of modern advances but it's all ruined by throw away culture/ deliberate obsolescence.
