Richard.
- Cambridgeshire
No they aren't on mine.Are the cross and compound nuts adjustable on these as stock?
The ones behind the cover are for threads and won't help you for fine cutting feeds. I had the same issue and just played about with the numbers till I got a really nice feed speed for cutting. I'll send you my combination tomorrow.Cheers Richard, at the moment I have a pile of gears and some shafts and not ashamed to admit no idea what goes where, I will work it out eventually but any help to shortcut the task is never refused.
There is a chart for gears inside one of the casings but I suspect that is screw cutting related, before I could delve any further I gave up when I sensed hypothermia kicking in and retreated to the warmth![]()
I'll have a look tomorrow, was giving the back gear a serious 'frowning' at today, could see where it moved to, obviously engages with the head gearing and has an adjuster to ensure meshing is set right but that's as far as I got.On the head stock tucked away in the pulley recess there is an oil nipple on mine and it's almost impossible to get to without a fine end oil gun. Not sure if yours is the same but if you don't get oil in there it knocks during operation particularly when using the lower speeds with the back gearing.
Yes, got it right.
There will be something to disengage at the same time as engaging back gear btw - just in case you hadn't spotted, if you engage back gear without disengaging the 'normal' drivetrain it'll lock solid and maybe strip teeth.
I have a book that Tinbasherdan gave me for the M7, very handy to get the gist of it but yes the specific book for my model is on my shopping list.My advicebuy or down load an instruction book. Or one of the many amateur lathe books covering myfords etc, worth every penny instructions....if you ead them ..
Or google images if you dont
Spot on..pm heading your way@cumbriasteve I have a manual [ d/loaded in anticipation of Maurice's arrival] giving notes on operation, installation & maintenance in PDF format. You're welcome to a copy if you think it'd be helpful - PM me your email address if you want it.
Any chance of nabbing a copy of that manual please slim?![]()
yeah I think I saw an allen screw in among the head gears... will have a better look tomorrow![]()
That's how the super 7 worksSome old lathes used a detent pin in the bull gear to lock it to the spindle; you pulled it out as you flipped the backgear in. Disengage backgear and leave the pin out, then wonder why the chuck's not spinning![]()
There is two flat head screws which hold the lead screw nut in place on the top slide. If they are loose the nut moves in operation causing binding and exaggerated back lash. I know this cos my top slide was also tight feeling. A little nip on those solved it straight away.
