Doing the next one. Cast iron dust everywhere.I recently acquired a between-centres sine table at a very good price. The castings on both movable supports have in the past been broken and repaired. Although it does not affect operation, I considered the weld repair hideous and deserving of immediate repair. I'll probably repeat the same repair to the other casting that has been brazed.
Here are the before and after photos:
Done....
As you can see I found it. At the last dregs of my coffee.
That's the problem.@Barking Mat ^^^^^^^^^^^^ you're going to have to paint the whole boat now!
But I appreciate your pain.Just a blower motor
Poxy French engineering.
LHD it's a sub hour job. RHD it's a 5.1hr job.
Sounds like the clutch master cylinder on my TT. On a LHD car, it's dead easy. On RHD, however, not so much. Factory workshop manual doesn't even mention it, probably because they're published by an American company.Just a blower motor
Have you ever changed the clutch cable on a Renault 19 16valve?Just a blower motor
going to guess it was similar to a R11 cable - maybe not the gearbox end, but the under dash end, getting the thing straight and un-stressed . . . probably explains having to replace it again 18 mths later.Have you ever changed the clutch cable on a Renault 19 16valve?
Looks like the access to the brake master cylinder on a RHD Alfa 159 V6 - I can see the bleed nipples, I can even just get a spanner on the front one and crack it a touch . . . the rear one however . . . I've had the scuttle apart, the wiper mech out, jacked the engine around, and still can't get to it well enough. Even bought a sidewinder ratchet to attempt it better - and then discovered you still need to flick the lever on the ratchet head to reverse direction, so back to square one . . . now contemplating one of those chain drive sideways extensions . .Sounds like the clutch master cylinder on my TT. On a LHD car, it's dead easy. On RHD, however, not so much. Factory workshop manual doesn't even mention it, probably because they're published by an American company.
The yellow cap is the (undone) fluid reservoir, the clutch master is just down and to the right of that as you look at it.
It might be similar, it's stuck behind the back of the engine (exhaust manifold?) right against the bulkhead. Total pig of a job.going to guess it was similar to a R11 cable - maybe not the gearbox end, but the under dash end, getting the thing straight and un-stressed . . . probably explains having to replace it again 18 mths later.
Original lasted a decade. Snapped mid gear change on the way to work up the hill out of Bailiff Bridge - its a bit steep, so forward momentum was rather rapidly decreased until I managed to get a gear, any gear. Parked carefully at work, bump started it by rolling downhill, drove home carefully that night.It might be similar, it's stuck behind the back of the engine (exhaust manifold?) right against the bulkhead. Total pig of a job.
This was my missus sisters boyfriends car done many years ago in a Tesco's carpark.
As for the 18 monthly replacements, yes that exactly how long they last! Two of my mates had one (the same car) and that's how long they last.
That one also had intermittent starting, the started motor would get too hot next to the exhaust and refuse to turn. Utter tosspot of a car.
