AT AT?Nowhere near finished, but at least its starting to look like something.
^^ There used to be a mine like that on the prom at Fraserburgh. A slot had been cut in it and it was used as a mahoosive charity collection box.
It might still be there, can't remember if it was when I was there last.....
It will be..AT AT?
To add a bit of variety to my fitness routine, I thought I'd add walking with a weighted rucksack.
There are plenty of ideas in the internet about what to use/how to pack the rucksack; but I thought this idea was neat:
It's just a metal plate. Various weights are available. 10/20/30 lbs.
I have plenty of Olympic sized plates in my home gym, but they'd sit at the bottom of my rucksack. From what I understand, the weight should be kept high on the back. After a bit of looking about to see what I had going spare, I came up with this:
5 layers of 18mm MDF cut to fit the rucksack. The 5kg plates shown sit in a shallow U-shaped groove to stop them rolling out the side.
I had a walk with it this morning. All good apart from the plates rattling a bit. Foam stuffed between them should sort that out.
A bit of sanding still to do to round the edges off.
would you not be better off with a water container?
that way if something happens, trip over sprain an ankle,fall down a rabbit hole or something you can tip out the water and hobble home
Yes, that idea crossed my mind, but water is too bulky for the amount of weight I want to carry.
Yeah, pretty sure they were at lots of coastal resorts, seen them years ago in Dartmouth, Maldon in Essex and Barry in South Wales. I think they all collected for the same charity but wouldn't swear to it.
A load of pie cuts. Not nearly as delicious as it sounds.
The angle of the cut is 4.5 degrees so each piece has a combined angle of 9 degrees. It's actually going to be 2 45 degree bends for an exhaust.did you Guestimate the angle to cut ?
also is it a practice piece or for a suspisisik supis spusspusif one off job
