daedalusminos
- Norwich
It seems that these old things do a lot better if you just leave them alone.
In this case. Modern lamp oiol burns hotter than old paraffin.It seems that these old things do a lot better if you just leave them alone.
You of all people should have known that. Ask any pyromaniac.In this case. Modern lamp oiol burns hotter than old paraffin.
New lesson learned.
I did.You of all people should have known that. Ask any pyromaniac.
Pretty much all automotive water pumps weep due to the type of seals used.After the Meyle water pump only lasting 2 years onmy Audi A8 before weeping at the seal it was time to fit a new one - SKF this time but I'm not convinced the quality is any better.
....and surprise surprise, another sheered pump retaining bolt...
Fat chance of finishing the job this weekend!
I did.
But me was on holiday.
Perhaps I should have quantified 'weep' - about 0.5l/40miles.Pretty much all automotive water pumps weep due to the type of seals used.
That amount isn't a weep!Perhaps I should have quantified 'weep' - about 0.5l/40miles.
Animal!!!Today I have mostly broken a teng 3’ pry bar. snap on wouldn’t exchange it when I bust one of theirs, which is why I fell out with them.
I will see tomorrow if Teng will warranty this one…..
View attachment 334513View attachment 334512
Is that your current joke ArdyShocked at that.
t
The capacity of the pun met much resistance
Well sometimes you just have to run the cables to each winding end. I saw this on an atomiser motor (600kWor so). The atomiser was a quick change job, where you had two IS plugs and sockets, three cores and earth in each one. We had to change the damaged sockets once, it really had me ****ting myself in case we did exactly what is described above.I can well imagine, one of guys broke the stop button off a 22kw 3 phase machine once and to get through the day used the phase reverser switch to stop the motor. Of course one time he went past OFF into opposite phase and blew the 63a MCB apart so violently the front came off the housing
Why did the dummy reverse the phases in the starter? If he had done it at the motor there would have been no problem and it would probably have been quicker.
Do the replacement glasses for those storm lanterns still bear a cast in the glass Elephant & carry the words " Made in India " ?
Is if the bolts sheareThat amount isn't a weep!
Are you sure?
